Hi guys,
Quick question... im after roughly 230awkw on my gts4.. will a stock rb25 turbo get me this ? i know about that ceramic shit but if the ceramic wheels replaced can i achieve good results without going and spending a couple of grand on a new turbo ?
just asking coz theres one for sale for 100 bux with a dodgy actuator on another thred.. might grab it if u guys give me good feedback ?
cheers guys!
https://www.sau.com.au/forums/topic/304744-rb25-turbo/
would this be a direct bolt on to replace my rb20 one? also for the time being is this a beter turbo untill i get it high flowed and stuff? ill be puting my rb20 actuator as the one on it is apparently not holding boost so what do u guys recon for 100 bux should i grab it ?
https://www.sau.com.au/forums/topic/304744-rb25-turbo/#findComment-5045508
If the turbo itself is good and its only an actuator thing then it is pretty cheap. Do a search for putting 25 turbo onto a 20 :D
https://www.sau.com.au/forums/topic/304744-rb25-turbo/#findComment-5045532
Straight swap, you will just need the turbo elbow with the turbo. Everything else will bolt straight on. If the turbo is fine and its only the actuator than that is a good upgrade for $100 assuming you can swap the turbo yourself. To put it into perspective, i sold my stock turbo for $250.
https://www.sau.com.au/forums/topic/304744-rb25-turbo/#findComment-5045549
Quote seller "A little in and out on the rear housing turbine, but no shaft play side to side "
so all i need is the turbo elbow and I'm set i really wana do the install myself as i really wanna learn about it all and want to give myself the experience not afraid to attempt it... am i going to need gaskets n shit ?
https://www.sau.com.au/forums/topic/304744-rb25-turbo/#findComment-5045559
The turbo sounds to be in good condition if the seller is telling the truth, for $100 worth the risk.
Yes you will need a T3 exhaust gasket that goes between the manifold and the turbo. Your dump pipe gasket might be fine if it is a metal one, however replace it anyway since it is all apart and the gasket doesn't cost that much. You may need some washers, bolts or nuts if some need to be replaced. Good to hear that you want to do it yourself, it's the best way to learn and you will learn a lot from doing this. Just follow the instructions on some of the threads on SAU and if you have any questions while doing something ask some one to make sure you don't have to pull it all off again. There isn't much that can go wrong so go for it.
Edited by PM-R33
https://www.sau.com.au/forums/topic/304744-rb25-turbo/#findComment-5045569
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
