Hello,
I have 2 Greddy gauges and some pods for sale. All gauges are electronic (memory and warning) with the control box and wires.
All sensors are included with the gauges. Basically just need to be wired up and there ready to go.
Condition: Excellent
Gauges: All 60mm
1. Water Temp (Will sell with the radiator hose sensor and Samco hose)
2. Air Fuel Ratio (Includes Sensor that needs to mounted to exhaust - Needs to be wired up - had to cut to remove from car)
Looking for $175 each FIRM.
As for the pods: (From R33 GTS-T S2)
A-Pillar twin - $40 (Pick up only)
Dash Mounted Tripple - $40 (Pick up only)
Just send me a PM if your interested.
I have pictures of the gauges with all the included gear. Will post them up tonight.
Cheers
what suburb are you in, im after the gauge pod, got any pics of how it sits on the dash?
Edited by W0rp3D
Hey mate,
Im in Ormond. (Just near Caulfield).
Ill try and dig up some pics. If you have a passenger airbag i would NOT recommend this. It sits over that side of the dash and is angled towards the driver.
Cheers
Hey mate,
Cheers
Mine is a S1, no airbags.
No worries,
Ill get some photos of it on the dash.
Are S1 and S2 different shaped dash?
Cheers
Will have a look at pics but i dont think so, just that S2 has the passenger side airbag.
Ok so fitting should be ok. Ill get some pics of what it looks like.
Cheers
Water Temp gauge is sold.
Everything else still available.
Sorry W0rp3D i haven't had a chance to get pics of the holder on the dash. Ill do it this weekend.
Cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
