hey guys can you rember when you first bought your new car how good it feelt ;). i just picked up my new xr8 ute i know its no skyline but damb i cant stop going to the garage to stare at it making sure shes still safe haha. im sure my crazyness will fade once it gets dirty but you cant beat that feeling :D
