hello resident suspension experts, I have decided to turn my GTR into a time-attack machine for a big race event coming up (modified tuner shootout). it will go back to street car duty afterwards, but i am working hard to make the car competitive for the event. We got 2nd place the last 2 years in street subarus and we dont want to give that up. A street subaru wont get us 2nd this year - there will be a dedicated track porsche 911 twin turbo awd as well as the sierra sierra cosworth evo so we have to be on top of our game to do well.
The chassis and engine are VERY solid and have plenty of time with no problems. Specs are:
full roll cage, proper bracing in the right spots
r34 gtr brembos, pfc 01 pads, brake ducting
R32GTR front suspension, caster changed to 7degrees through custom upper mounts. Stock swaybar, Stock Upper Arms, Stock lower arms, Stock tierods, Quaife Front LSD, urethane swaybar bushings
R33GTR rear suspension, full adjustable links, R32GTR stock swaybar, nismo LSD
Tires are Hoosier A6 (Autocross compound for time attack) and BFG R1 (enduro + lapping) 275/35 on a 18x10.5
Torque Split is running fixed with 40-55-60psi in the transfer case (ATTESSA eliminated) depending on preference
built motor, single twinscroll turbo, 680hp on E85 (helps response), good oiling system and cooling
I am getting a set of triple adjustable motons, and they will be used only for the track (will switch out to my koni 28 series for the street). Curious on what you guys have used and i may also end up picking up some ohlins since i was offered a set at too good a price to pass up.
Please advise on swaybar, roll center adjuster height, tie rod changes, spring rates, alignment and anything else pertinent. We are taking care of aero and improving the cooling right now, will jump on susp middle of next week, need to make some decisions. thanks for reading
Edited by Full-Race Geoff
https://www.sau.com.au/forums/topic/305269-time-attack-suspension-setup/
Got a bit of work to do in a short period of time then....
Torque Split is running fixed with 40-55-60psi in the transfer case (ATTESSA eliminated) - this will make things interesting. Can I ask why you chose to do it that way?
Cusco make good, (albeit fixed) sway bars. I would recommend one for the rear, not so much for the front where softer offerings may be better..
Spring rates are dependent on where you are running (ie what track) but also (importantly) on the Attessa set up. With a fixed set up you could arguably afford to increase the rear spring rate relative to the front to help remove understeer.
first recommendation is brakes. you will need something at least 355mm front rotor with some bigger callipers (bigger pad area) than the stock 34 GTR brembos if you want to compete with cars like you mentioned.
Hey Geoff, try posting this up in the Motorsport section mate, may get some responses there from people who actively race their GT-R's.
Thanks dane, just posted up and added some pics http://www.skylinesaustralia.com/forums/Ti...tr-t306963.html
thanks for the advice. unfortuantely the money is blown on the aero package and motons. the r34 brembos will have to do, we got a SUPER aggressive pad that should shred rotors so well see what it can do
From the looks of things you are running a full GTR driveline and engine combination in a S chasis car, this is fairly custom set up and there would have to be some differences from a normal GTR or S chasis car so doubt you can't use the exact same suggestions for these cars.
What is the results on the corner weight scales?
Edited by boxheadmr
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
