lolz
search?
yellowpages?
godzilla, stz, mercury, efi performance.. to name a few
mercury could not get it to start and had it 4 3 weeks. They had it set on number 4. I wont someone that nos what they are doing. 500hp motor. Dont wont boys playing with a $20 grand motor. Never again !!
yeh maybe if you included that in your first post mate :O
go efi performance, from what ive heard they have their shit down
or redline efi if you dont mind driving to burleigh heads
Might wanta re-think your topic title, saying "dyno" does not do much for what you need...
that said i changed it to help attract the right attention...
here is a list of places to consider (based on my personal view and in no particular order)
* Godzilla Motorsport (RB professional - convenient south Brisbane location)
* PITS - Matt Spry (Depends on what ECU you run tho as to what service he can provide)
* Gavin Wood AutoTech (Great choice for the gold coast and Matt is busy or cant help)
* EFI (Also a great choice for an RB engine if your in that area)
* RPM (Good choice for those up towards the north ie. the sunny coast peeps)
Thats about it for the moment, there are a few more in mind but not sure how good they are with RB30ET's...
should add that EFI have some highend diagnostic tools if you are having problems.
they do a lot of checks before the car is strapped down on the dyno.
but the best thing that I found - they talk to you, not at you, and they take the time to explain things in great detail.
STZ in virginia are pretty good marty is a nice bloke is only charging me 88 bucks for a simple tune run make sure all the sensors are working and getting good signal to coils and stuff not a hell of alot more for a power run
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
