After owning this for 3 1/2 great years, this car has proven to be exceptionally reliable. Black on silver, i would rate the body as an 8/10, only body flaws are a few scratches on the corner of the rear bar, and a little key mark around the locks(thanks to my 2 year old)
The only issue we have had with the car was the common roof rust, but the rust was fully removed, treated, welded gal painted and the roof resprayed professionally in 2 pac. An electric sunroof was fittead at the same time.
We bought the car having 112,000k and the timing belt and water pump were replaced by the car yard as a precautionary measure. Apart from routine servicing i have fitted a set of evo3 lifters as the stock rvr ones are notorious for getting noisy. The injectors were cleaned about 40,000k ago. The ecu has been remapped to improve power and economy.
Currently has october 23 rego in NSW and 177,000k.
Rear tyres are fairly new
Heavy Duty Tow bar
Reversing sensor
Immobiliser
Factory bulbar
Factory Driving lights are included, however one has a cracked lens(not fitted)
I can be contacted on 0423 328 738, or email <script language=JavaScript type=text/javascript> \n [email protected] <script language=JavaScript type=text/javascript> This e-mail address is being protected from spam bots, you need JavaScript enabled to view it <script language=JavaScript type=text/javascript> , or PM. Please contact me for photos, as i dont seem to be having any luck attaching th
Only selling as i have bought a business that includes a vehicle.
</SPAN>
Edited by Adriano
https://www.sau.com.au/forums/topic/305322-1995-mitsubishi-super-sport-gear/
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
