Mate considering he has only 150 feedback items - what do you honestly think?
You'll be hard pressed to find 10 people who've purchased from that person to be honest. :cool:
IMO buying R33/R32 N1's is a waste. Bush bearing, older design etc etc.
Just get R34 N1's or some Garrett's if you want an upgrade.
I asked his same question a few weeks ago but go no replies.
I asked the seller a couple of questions and he seems pretty reasonable to deal with.
If you just wanted steel wheel turbo's, which run more boost without going chick chick boom then these are very reasonable for $1250 for a pair (exchange), which is a fair bit less than around $2,500 for N1's or 2860-7's etc (obviously these are much better turbos but they would want to be at double the price).
He also sells steel wheel rebuild kits for $330 or something but then you have to get someone to rebuild and balance the turbines for you.
If your used to a standard GTR these aren't going to be much lagier and will have better power (especially if over 1 bar).
Theres a guy on the forums Hypergear or something who rebuilds 32/33 gtr turbos to N1 specs for $660 each, which again is pretty reasonable.
unlucky for you :(
most ebay threads end down the same path though at the end of the day
R32/R33 N1 turbos - you will notice the lag, R32 items are even more pronounced.
R34's are less than each model before it.
The "$300" kit - will just be the wheels and not much else i would think?
You'd be looking at roughly $300-$350ea for a rebuild kit for each core (bush/journal bearing), then the wheels...
Then getting someone to balance it and so on. So his price of $1300 for two journal rebuilds with steel wheels is pretty much where it should sit
unlucky for you :(
Yeah the $300 kit was just for wheels and seals etc. And like you said by the time the are built and balanced you end up around $1300.
However I asked GCG about rebuilding my stockers and they said about $880 each, which was quite expensive (I said they were 32 turbos not 34 as that price is usually for a new cartridge).
For the money they sounded ok, but end of the day you get what you pay for.
Did you ask what type of core they would be using?
Rebuild with stock size wheels or wheels that involved housing machining as so-on as well?
Every little bit add's up, two turbos means 4 lots of machining if you are using slightly larger, and then $1700 would be reasonable :(
Depends on budget at the end of the day really, what you want to spend vs what you can live with performance wise.
Have a read at HyperGear's turbo high flow thread. From photos it appears that they use sleeve or roller
GT2860RS - 739548 - 5
turbo core in stock turbine and comp housings, Price is pretty decent. Not sure if they have stock R32's N1 wheels. You can always ring them and find out.
Other wise check your local MTQs branches. Ebay is really the last resort you want to use.
Edited by kwickr33
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
