hey,
will xmas has come and gone and it has given me some $$$ to spend on my car. I am going shopping 2morrow to buy some car cleaning stuff but i was wondering is there any places i should go to get a turbo timer, gauges ect? Hopfuly cheap?
Thanks aheaps :D
hey,
Thanks aheaps  :D
some guys are selling cheap timers in the For Sale Accessories or Business sections on these forums.. Apexi pen timers etc.
For example http://www.skylinesaustralia.com/forums/sh...ead.php?t=29089
not sure how his prices compare, but there isnt much variation.
as for shops i guess u could try xspeed etc
Motorquipe at whitfords city (NOR) has just opened and when i had a look the other day, i noticed they had some very good opening prices on gauges and the apexi TT, brand new was on special for $159. Thats pretty good, from what i've seen...
they have a medium sized range of autometer gauges and stuff like that, again for pretty good prices. Maybe have a look up there, if its not a huge drive...
go check out www.importscene.com.au
Gregg (managing director) is an excellent bloke, i think he is actually on holidays for a little while though, but if your willing to wait maybe a couple of weeks, drop him and email and tell him MirKz sent you and told him to give u a good deal. (he should knock some $$ off for ya).
get a pivot baby timer for sure.
I got one and pulled the electronics out of it and set it all up behind my clock so that the clock face is now that of the timer and the buttons on the clock mimic that of the timer. ie. power is now reset button etc... looks acool at night too and it hides it out of sight. if you need a hand with it let me know and i can help.
Nate
I'm definately interested in doing this ..
What color are the numbers on the pivot baby timer?
Jason.
Nate
pivot timers have red numbers... not that bad really... breaks up all the bloody blue on the dash.
putting it behind the clock is not so hard as it is figity :)
you will have to pull apart the clock and make a square hole in the centre of the clocks PCB (printed circuit board). you wil also need to make sure that all tracks are cut which link up all the common rails/tracks on the clock pcb (easier said than done)
once that is done...
to mimic the clock buttons to do what the power, seconds and minutes buttons will do, you will need to solder link wires between the buttons on the clock PCB to the buttons on the timer PCB... once again, easier done that said.
Thats about it! if you have done this correct all you will have to do if put the clock back tp together, with a hole in the back of the black clock case, so that the timer pcb will slot into the whole clock case and put back into the dash as removed.
If you have cut the holes in the clock PCB and clock casing tight enough the timer PCB will hold itself in tight enough, if not you will probably have to affix it to the case do that it doesn't fall out when you break hard ;)
i will post pics toght if i can, otherwise let me know if you are interested and i cann aid you in the creating from hell :)
I'm definately interested in giving it a go, shame the colour is red, was hoping for a bright blue ...
I just have to wait till I get new bankcards (bastards stole my wallet) before I buy anything.
Will let you know closer to when I get it :(
What suburb are you in?
yeah no worries,
just let me know when you want to do it... i would say for you to get it all installed (harness and all) and when that is done you can bring your clock and timer over and i can make the mod for you... should only take about 1 hour. i live in winthrop
not too sure but i know that you timer should have about 5 or 6 wires (correct me if im wrong) like ign, constant power, ground, acc, and hand-brake coming out of the back of the timer. if you can hook those up and leave enough so that you can cut the wires and re-solder them back again, you should be right. all i will need is the timer itself and the clock.
when i said harness i really ment the wires that come out of the timer. i dont think that i had a terminal block or anything with mine.
hope that helps
Nate
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
