Again,
Just thought it might be interesting. Ive been on the cheap gathering items for stag in the looks department.
If things go according to plan mine will have dayz bodykit, masa grille, eyelids, nismo sideskirts and autech wing.
Should be good, I'll show you mine if you show me yours.
Nothing sus. :(
https://www.sau.com.au/forums/topic/305435-ok-ladies-show-us-your-kits/
  • Replies 87
* Waits for harts to enter the room *
Im waiting.
Just remember mines on the cheap, enuf to paint it and I got my interests invested elsewhere on the car. But it will sit like a pitbull on heat, remaining mainly factory for fitment issues. Although my dayz frontbar is semi hacked and also needs painting (couldve done with one of those factory antenna thingyz in high rise shitty car parks.) :D
From memory he grabbed a whole masa kit?
I am keeping mine stock, just not into bodykits and mods
Just R34 conversions hey - doesnt really make sense?
Not into mods - I thought you were looking at a high flow or something, most of my money is going under the hood next month.
What skirts and rear bar did you use? You have ganador mirrors right?
I am thinkn that with the lower nismo skirts will make my dayz front bar might look a bit high, but i'll give it a go.
Panel and paint has been rescheduled for two weeks due to still collecting parts.
I think "unique1" has something similar to what I will do.
Edited by dirtyRS4
I hacked the front of my dayz bar
I have trashed the bottem of mine from carparks, and might do the same when the gtr cooler is fitted.
Dayz, dayz thats all I gots ta sayz. I got a fair few questions to ask you soon.
For a car so worthy shouldnt you treat it with some nismo skirts, masa grille and S2 wing?
By the way hows that advanced bucket mod going (concept is good - execution is bad) - ROFL!?
I will show you my CAI effort soon. ;)
Edited by dirtyRS4
working on the rb26dett track car atm ;)
awaiting a 18psi turbo actuator for the stag, will install that & manifold then see if my old cai setup fits.
pre-bucketing around ;)
But does it have a highly modified grille?
Just jokes, gotta speak with ya about cams, valve springs and other complex go fast boring stuff.
I know you went out of your way to get those wheels, nice for size for track work. Which Dominoes did u ring - with that tough dish?
SSS is gone, I nearly cried (that car helped me out bigtime when my stag was in peices a number of times).
Money to spend now. :merli:
Edited by dirtyRS4
yes !!
lolz
re: cams, yeh no worries. I went with tomei poncams 256/256 with 8.8mm springs
new valve guides, seals & seats + mild-porting work. add in a nice head gasket & all is good
18psi steady day in day out will be nice, at least until the rods/pistons/rings/bearings cry out ;)
Dude,
Thats some real funny shit.
It looks like half a 400r grille on a four door 32, 25/26 or 26 rwd?
But you were right. By the way I like the custom fist imprint in the f/r quarter panel?
Interested to see under the bonnet.
R32 four doors look tuff with a URAS kit.
rb26dett rwd 5spd manual rebuilt rb30 box button clutch
tein suspn, new highflow turbos, gtr fuel pump,
got oil cooler + filter relocator, other goodies like the $5 roll cage (bhpsteel made)
just need slicks, power-fc & injectors, perhaps a surge tank too,
all stripped ready for her 1st outing as a trackday-only biatch
mate will weld it in after I cut it to suit
then drop in my seat and harness
see how it goes, drive nice from melbourne to radelaide just b4 xmas last yr
the tree out front of the house dropped a 2tonne branch on her a few days after I got her home!!
lol - hence the dodgy front panel
Two words mate - "how reliable" are ya cars? The teins must be pretty hard as for a track car. How are the high flows, good spool up -not one big turbz? Up grade to GTRS turbos? Spose forging would be too much and winding up the boost on the high flows would be cheaper route till sumthin lets go.
Mickey thompsons, surge tank and cage and harness will be needed. My mate ripped out his NEO 25 and has nearly finished dropn a LS1 motor in a S13 and hes doin my car soon. I gotta say nice four door rwd track taxi! Good taste dude. Me wants a go!
1000 kgs and 285kw built LS1 motor. The S13 will put a bigger grin on my face no doubt. ;)
Edited by dirtyRS4
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
