Hiya,
Superlap needs volunteers to help out with the 2010 World Time Attack Challenge! :)
Are you a motorsport enthusiast with some track experience? Sign up for the Superlap Volunteer Program and see the world’s biggest time attack for free!
That’s not all, for your help during the event we’ll provide you with the official World Time Attack gear and an unrestricted access to the whole track and our corporate suite. We’ll also throw in a full merchandise pack and lunch to boot!
This is a unique opportunity to be a part of the 2010 World Time Attack Challenge and participate in the biggest event of its kind in the world!
Superlap Link Click on Me
If you have any questions please PM me!!
Thanks Jess
https://www.sau.com.au/forums/topic/305610-superlap-2010-volunteers/
  • Replies 51
Hi Alan,
There are a few roles..
I need flaggies!!! most important, Pit lane marshall's, Dummy Grid and maybe even a Starter but that is to be confirmed!
Scruitneers are to be confirmed also
Would love to have you on board if your up for it...
Russell, would like to have you for both days if possible...Friday and Saturday!!
Fill out a form for me and send it and will let you know finer detail's closer to the event I.e time to arrive at the track
Thanking You!! :P
Hey Jess I might be heading up from Melbourne with a couple of mates to spectate as we do not want to miss out on this event!
I don't have any track experience, but id be willing to put my hand up to help if you need it. I see that in the application forms first timers will be considered, I might send one in if you want?
BTW Jess in the form it asks for CAMS - Is it necessary? I filled out N/A on the form (I'm Steven Trajkovski, my cousin Steven Bojkovski also applied wanting to know the same).
I do have AASA though. If it is required and by any chance I get selected I will apply.
Cheers
Steve.
I dont have any track experience (did some amatuer flagging for a drift day...not sure if that counts?)
But also don't have CAMS...i'll assume the chances of me getting anywhere with this will be fairly low?
Cheers
Steve.
I will have CAMS official forms for you to fill out on that day!
I will have CAMS official forms to fill out on that day! so dont worry about that. You will be giving information in the morning in the Officials breifing and will be helped over the radio.
Fill out a form Black Widow and send it in...Will be letting people know closer to the date :cool:
Gee you're really pushing this Jess :)
in for pit lane marshal!
Hope I get pitlane too given my experience (big hint to Jess) :P
Can't wait ... going to make a road trip of it :cool:
Gee you're really pushing this Jess :P
Hope I get pitlane too given my experience (big hint to Jess) :down:
When do I not...Roo :P I love Superlap!!!
So glad your making the trip up!! Wont be disappointed :)
Thanks
Edited by Black Widow
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
