Today I had a new alarm fitted to my R34 GT-T since the factory/dealer alarm doesn't immobilise the car – it only honks the horn and flashes the indicators.
My problem is, the shop who fitted the alarm can't work out how to disconnect the factory one without using the Nissan key unlock button - although the alarm stops as soon as the ignition is turned on.
Does anyone know how to disable the factory alarm? I've had a search through the forums but haven't found the answer. Car is a 2001 GT-T Series II.
I know how to sort it out..
Take it to a proper installer - not someone who reads off a cheat sheet and has no real idea about wiring in cars.
That's exactly what I did in the first place - the installer I went to is an authorized dealer for the alarm I purchased and they were recommended by a number of people in the ACT threads.
sorry cant tell anyone how to disable an alarm, for obvious reasons
do not try to do it yourself, go to a reputable shop who knows what there doing. if they dont know how, walk out, cause they really dont know how to install then.
which ACT store. I know of 4. sned me a PM/I deal with all 4 of these daily :)
can't PM as I'm still below the 10 post limit but they are a well known audio installer down in Tuggeranong
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • Yea pedal box and no abs
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
