  • 2 months later...
  • 1 month later...
Hi,
Pics of this car (some are in the Trading Post but these are higher resolution).
post-61769-1274840284_thumb.jpgpost-61769-1274840714_thumb.jpgpost-61769-1274840295_thumb.jpgpost-61769-1274840304_thumb.jpg
They said someone from Melbourne 'almost' bought it for parts. (Anyone from here I wonder?).
The pics show the doors have been patched and the D/S guard. Boot lid has rust. Odometer not working, estimated at 200000km according to the ad.
JH
