- r34 gtr powerfc with hand controller $950
- Racepace 3.5" rear muffler, super high flow but quiet (was used on my 360kw atw R34) $500
- r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $180
- r33 gtst rear rotors and calipers $250
- s14a genuine ganador aero mirrors (painted pearl white) $370
- s14a rear tail lights + center garnish $180
have u still got the power fc
  • Replies 90
r34 gtr "Z-tune style" carbon fibre bonnet $750
r34 gtr vspec rear bar, bayside blue $350
r34 gtr carbon fiber lower lip (cracked, needs repair) $100
r34 gtr boot lid with tail light, silver colour (holes where wing has been removed) $100
r34 gtt Cusco 1.5 way type-MZ limited slip differential $900 > awesome diff! locks beautifully under acceleration
r34 gtt Bride drivers side rail for Bride bucket seats (e.g. Zeta II, III, Guardis III) $200
pickup in melbourne or can arrange interstate freight at cost.
i can get quite good prices on freight, email me with your location/state for prices
[email protected]
do u have the cracked carbon lip
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
