Hey guys,
I'm interested in buying a R32 GTR.
Any problems with this car that I should no about or any tips and etc?
I've seen lots that have rebuilt engines, does this mean that I shouldn't buy one that doesn't have a rebuilt engine?
I hope their not like rotarys which needs to be rebuilt every 100,000kms...
https://www.sau.com.au/forums/topic/306009-buying-a-r32-gtr/
Hey guys,
without going into detail , buy something stock , original engine with original kms sounds tough but they are out there , 25k price range , anything under that forget it , paint missing on the manifold and cam cover is a good indicator of age ! majority of cars around the 100,000 km range will have some paint missing depending on how hard its been treated . chassis rail dents/bends , panel allignment . Anything rebuilt is ok just get it checked out by a mechanic . :thumbsup:
Look out very carefully for any rust. Obtain the VIN # and check it against the VINS Fasted thread on this forum. Hidden rust is common on cars from Hokkaido or North Honshu.
Compression testing is advisable.
Due to age, also check suspension, bushes, joints.
Hopefully service history is good/complete.
Don't be discouraged if you come across some that are owned by people who are anything but enthusiasts. So be patient.
After finding one > buying one, you might wish to upgrade the brakes unless it's a later model V-Spec.
Reputable importers are good sources to use. A couple are on here - Hello-o-o-o-o?
Hi Terry :worship:
Azn, just remember you get what you pay for - a poor quality/cheap 32 GT-R is a good recipe for a nightmare. Spend at least $20K on one and you'll get something nice.
Sounds like you need to do a bit of research on this site.... Its not the type of car to buy without being WELL informed.
There are plenty of terrible examples for sale and you DO NOT want to end up with one of them cause it will spend more time off the road than on and will cost you a small fortune.
Edit: They are nothing like rotaries needing 100,000km rebuilds... the reason sooo many have been rebuilt is that people boost them high and drive them very hard and track them and then they go pop. Any car that has been rebuilt has either not been well looked after or driven... other than when some owners decide to take out the engine and rebuild it with forged internals as they plan to modify the car and want to strengthen the engine
Edited by r32line
Thanks for the advise guys!
I'll do some further research on these forums and I've made up my mind and decided that this is the car that I want!
Can anyone post some links for important threads about the BNR32 just in case I miss it in the Search feature of the forums?
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
