selling my rb26 race head, i changed direction with my engine, after experienceing electrical problems with the gtr putting it in a workshop for a very long time and after alot of thinking deciding to change a few things, so hence the sale. i had a new head built for my new setup.
seen about 1500-2000km driving and dyno runs
was part of a setup that made 565awkw @ 21psi on pump fuel, so the head is good for it and is really really strong.
looking for around $7500, which is merely half of what it cost to build! needs to be sold asap to fund new setup.
Parts list:
Ferrea 1mm oversize stainless valves
Aftermarket valve guides
Apexi V-Max SPL springs, retainers and buckets
Apexi V-Max SPL 280 deg 11.5mm lift cams
Tomei camshaft stud kit
Trust cam gears
New stem seals
whats been done to the head:
Ported intake + exhaust runners
Profile guides
Polished + cc'd chambers
Unshroud valves in chamber
Flow benched and runner flow equalised
Steam hole modifications/water gallery modifications
Clearanced for high lift cams
Drilled for 1/2inch head studs
Flow figures:
Lift Int Exh
0.05 51.9 46.4
0.1 100.4 94.5
0.15 147.2 134.8
0.2 186 167.5
0.25 221.3 197.2
0.3 252.4 219.5
0.35 277.5 229.7
0.4 292.9 236.8
0.45 304.7 240.8
0.5 309.2 241.8
heres a few pics before the head was fitted up..
https://www.sau.com.au/forums/topic/306140-rb26-race-head/
hey its only a 3L haha i built a new head because we did specific porting with it after some guidance from o/s regarding circuit work coz thats where i wanna focus most of the car, but its all goin together this week with a T51R KAI, so prob around 500AWKW but really responsive, torquey and a very nice curve. hows ur car goin, my bro saw i i think and tried to tell me to put an auto in it haha
https://www.sau.com.au/forums/topic/306140-rb26-race-head/#findComment-5110161
Are you using that spare os rb30 you have or a nitto crank and rods from croydon?
ye im using the OS RB30 i had here. this car is doing my head in! haha 3 years now
hey sorry i know its a little off topic..
you dont have any rb30 cranks lying about?? i need one to keep my build going.
no sorry. i do have a mad head for sale haha
https://www.sau.com.au/forums/topic/306140-rb26-race-head/#findComment-5111143
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
