Hi everyone
selling off all my un-needed engine parts as i have built a complete new engine, was going to drop some pistons in this block and sell but dont have the time or money.
block and crank out of my r33 1998 ser3 GTR 52,xxx it has suffered from a bad tune and a melted piston no.6 and need a bore out and some new pistons.
would like to keep the bottom end together and sell it complete.
so
block std bore
5 std pistons and 1 melted piston
6 std gtr rods
r33 crank perfect condition
std oil pump
std water pump
what you see in the pictures is what you get.
$1200 pickup only
r33 sump/diff complete $450 pickup only
r33 GTR front dba 4000 series rotors. these where fitted done 500km then i upgraded my brakes so only just been bedded in with pads when i removed.
$500 pickup or $45 postage
r33 gtst caster rods $80 pickup or $10 postage
XTD superlight flywheel and jim berry single plate button clutch pull setup, has done run in tune for my new built and slipped with the 400awkw as expected so was taken out straight away and replaced with a twin plate to finish off tuning. perfect condition some heat marks from the slippage but basicly brand new no warping on flywheel and 99% meat left on the clutch.
$600 pickup or $45 postage
Brand new Greddy timing belt $180 pickup or $10 postage
I located in yarraville and happy for local pickup.
txt me on 0416250596
cheers Travis.
Clutch/flywheel $600
flywhee is a 12lbs XTD and dosnt need machining just surface discolour from being removed straight after it slipped. bring a metal ruler if you want to check yourself and you will see the surface is perfectly flat.
dba 4000 front rotoes for r33 gtr $500
hardly used luck to have bead the pads in still has heat paint markers on side of rotors.
gtr r33 crank $500
gtr r33 block $400
gtr r33 dba 4000 rotors $400
rb26 greaddy timing belt $150
r33 gtr sump/diff $350
xtd superlight flywheel $250
jim berry clutch pull type $200
new falken 285/35/18 slicks pair $400
gtr r33 crank $500
gtr r33 block $400
gtr r33 dba 4000 rotors $400 $350
rb26 greaddy timing belt $150 $135
xtd superlight flywheel $250 SOLD awaiting payment
jim berry clutch pull type $200 SOLD awaiting payment
  • 1 month later...
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
