Hi All,
I'm looking at buying "APEXi Auto Timer" for my R33 Series II. I'll be also buying the wiring harness for it and I want to be sure I don't need to hack anything apart once I have this harness. Where does the wiring harness plug into?
Im not confident with cutting wires and so forth so I just want to be sure before I buy it. Also is there anything else I need to be aware of? Is the factory alarm OK with the engine going and doors locked?
Thanks
https://www.sau.com.au/forums/topic/30664-apexi-auto-timer-wiring-question/
Ok, I've found a good price a price too for the harness however perfectrun.com.au list it as "plug needs to be modified" also apexi-usa.com don't have a R33 GTST harness. Most places only have a GTR harness.
Does anyone have one of these workin in their GTST? Any ideas what needs to be modified on the wiring?
Factory alarm??? In my experience no alarm likes turbo timers, most will not arm with the ignition on. Is the turbo timer the pen style one? if this is the case you ned to splice into the computers wiring harness for the air fuel ratio meter to work. the english instructions are too hard to read due to poor resolution so use the japaneese instructions to view the pin layout of the ECU. :D hope this helps...
I got a response from Perfectrun.com.au and it all seems good, just need to modify the wiring harness plug so its fits the iginition plug on the r33.
Hi,
Connector part of the optional wiring harness needs to be cut slightly so the factory connector can be slide into it easily.
Regards,
Taki
Perfect Run
sales@perfectrun.com.au
By pressing the left/right buttons you should be able to. Sounds like a loose contact wire or ground wire. Does the display ever loose power? Do the sensors all work OK? Do the A/F and 02 display values?
http://www.apexi-usa.com/productdocumentat...nstructions.pdf
and
http://www.apexi-usa.com/productdocumentat...s_autotimer.pdf
  rs73 said:
has anyone managed to wire it up to handbrake wire? where do you find wires for the handbrake?
hi Rianto, if you remove your ashtray and the 2 screws behind it, then pull out the panel around the gear shift, it makes it easier to get the cup holder out. then you will see a yellow wire on the hand brake assy, thats the one you need. :D
Thank's Danny...
In re: car alarms not happy with turbo timers, I got an alarm which unlocks the door on ignition off and locks the door on ignition on. What happens is when engine was turned off by the turbo timer, my door will unlock. So the car will be vulnerable for 30s until the alarm's auto arm feature kicks in. My plan is to disable this feature, so when engine is running with turbo timer, I can lock the car manually. When timer runs out and turn off engine, it will not unlock the doors. Car is still vulnerable for 30s but at least now the doors stay locked. 30s later the auto arm kicks in. I can even shorten the 30s auto arm period for extra security, like 15s but not very practical when you don't need turbo timer, as you'll need to rush collecting your things to get out before 15s runs out and auto arms your car.
  rs73 said:
No it's none of those. It's Code Alarm :)
Oh well..... if it is a 2003 pro series Code alarm try this
1- keep door open
2- Turn key to IGNITION ON position
3- press and hold valet switch for 5 seconds (LED will glow constantly)
4- press buttons 1 & 2 of transmitter TWICE
5- LED will flash twice
6- once you have confirmed the LED has flashed twice
7- press button 2 of the transmitter to turn off ignition door lock feature
8- Siren will chirp twice to confirm feature is off
10 - turn off ignition and close door to exit learn routine
Hope this helps :D
  LastTemptation said:
paul, its all good mate, just sometimes doesnt keep it running when i remove the key...
should i re check all the connections
Did you hook the handbrake wire up? if the connection on this wire sees a bad earth then it will not allow the TT to operate. Some people just earth this wire
Auto trust, ill do that.. but the thing is, i havent installed the timer myself so where do u think that wire could be? is it straight of the TT pen thing or is there a lil black box where its all connected to.. ?
