Item Summary: r32 gtr - JDM work xd9s, carbon bits
Condition: Used
Reason for Selling:
Asking Price: 17999
Delivery Methods: PickUp
Contact Info:
Extra Information:
Hey guys looking at selling my gtr as I might be moving to Brisbane and might be getting a work car so the gtr in not needed.
Desciption:
1989 r32 gtr
Bought the car 6 months ago totally standard have since
- Fully repray of car in standard silver and fixed some rust in the rear arches
- Brand new set of Work xd9's in gunmetle 18x10+18 off set with new tyres cost me $2300 just for the rims
- Brand new top secret style carbon rear diffuser
- Just waitng on the standard side skirts to get finished painted
- Mines 320km dash reading 132,000km
- hks epromed computer
- Full Greddy hard air filter piping (have a pair of rb25 afm to go on)
- Set if 660cc injectors and fuel rail to be installed
- Alloy radiator
- Have been told that the engine had been rebiult when it came to australia have no proof but the gaskets on the intake side look new so some signs of a possible rebiuld
- Twin plate clutch really quiet yet very solid pedal unknown brand do have reciept of it being put in from previous owner
- Full echaust system again have reciepts from previous owner
- Has sound system no in car has been pulled out all wiring still there ( sub and amp) will give to new owner
- Had Tein suspension but took it out and replaced it all with standard gtr suspension (much more comfortable)
- Interior in resonable condition for its age, steering wheel has so wear and drivers seat showing a small tear in usual lumber support
Car has a current QLD road worthy
Location: Hervey Bay Qld but im Brisbane every couple of weeks
Price: $17999.00 ono willing to negotiate
Contact Details: pm me or 0435278050
https://www.sau.com.au/forums/topic/306651-r32-gtr-jdm/
will straight swap for a r34 4 door manual
or will part out
Wheels $2500
power fc $700 with hand controller
rb25 afm $200
Diffuser $400
Injectors and Rail $500
thats a total of $4300 of the price of the car so will drop the price of the car down to $14000 ono
https://www.sau.com.au/forums/topic/306651-r32-gtr-jdm/#findComment-5089785
  • 1 month later...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
