Hello all,
Just wanted to check something minor with everyone. I was just wondering how often one should send the car for a wheel alignment check. I'm feeling progressively harder vibrations in the steering at about 120km/h and above. had the alignment done in May, so is it supposed to be vibrating and stuff around this time? (6 months after last checkup)??
https://www.sau.com.au/forums/topic/30670-simple-alignment-issue/
You may have thrown a weight off one of the front wheels at some time. Or flat spotted a tyre as mentioned above.
It's worth getting the front wheels balanced and getting another alignment at the same time anyway. 4 wheel alignment was only 50 bucks last time i hade one (i think)
Actually, yea the weights on one of the front wheels was taken off after I had a meeting with a kerb. Had to reshape the wheel, n realign it. The dude who reshaped the wheel ended up taking the weights off.
Can Bob Jane's put some weights on the wheel for me? Cos i was wondering if that would become an issue later on. Man, I completely forgot about that. I'll check for flatspots too just in case. But yea, do you think a place like Bob Jane's or KMart tyres can put weights on the wheel, or would I hafta go to a rims place for this?
Thanks for the info guys
Nrage33 - this is from my R32 experience; i did have the same problem as yourself but not as bad. It was about 9 months and I brought it down to a specialist (http://www.fulcrumsuspensions.com.au). The guy pop his head under and car and came out with the diagnose immediately - the right side of my car is fitted with a different boot (i just got it replaced 3 weeks ago) as compared to the left side. The only way the alignment problem can be fixed is to get the same size for BOTH boot... anyways... he did his best with my car and the problem is 95% solved and i am very happy with it.
you may or may not have the same problem as me, but bring it to a specialist to have a look.
knore - yup, its called wheel balancing... no rims or tyres are 100% pure balance esp when spinning at high speed. the trick is to add small pieces of weight to balance it out.
Great, as long as I can take it somewhere, that's fine.
when the accident happened, a suspension control arm was bent out of place, but that was replaced straight away. There have been creaks and groans, but those have also been sorted out. Just have the vibrations. I remember when i got the wheel back, it was missing some weights, but i just left it at that, cos I didn't know what they would be used for at the time.
I guess passing around fulcrumsuspensions could also help. They may find something more
that could be the reason... most mechanics will change one side of the car with aftermarket parts without comparing the size/dimensions of the standard parts. bring it down to fulcrum to have a looksee. make an appt though.. that place is always packed.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
