Performance Parts Clearance Hks T51r Turbo Kit, Trust Sump, Arp Head Studs, Mahle Pistons, Sard Injectors, Hks & Os Giken Cam Gears!
Hi Guys,
Sadly my car will never come to fruition so im clearing out the garage
Used Performance Parts
HKS T51r-KAI Turbo Kit to suit RB26 (800ps version)
HKS exhaust Top mount manifold
HKS GT Wastegate
HKS steel exhaust gaskets
Greddy dual Intake Pipe
Custom dump/front pipe
4,000kms old, no shaft play what so ever, Inspections welcome
$3500
RB26 Ross Balancer $450
Tomei Cam Gears $200
Sard 720cc injectors with Greddy Fuel rail $915 FIRM (not seperating)
RB26 Sump with TRUST Sump extentsion welded $800
(Includes R34 GTR diff)
Venolia Pistons RB25 Good condition (needs new rings) $400
6x Stock Rb26 rods $150
GTR stock turbos $200 turbos (no manifolds)
Brand NEW
ARP Head stud kit to suit RB26 $350
Mahle 26/30 Pistons 86.5mm pistons/rings/pins $720
Gives a 8.5 Comp ratio
N1 Oil pump $400
only opened the box to look at it, never installed
HKS Timing Belt to suit RB engines $100
Genuine RB26 Nissan Gasket Kit (the one with a billion pieces) $300
1000cc Injectors Rochestor Brand comes with 14mm Top feed fuel rail $500
HKS Cam gears (New design pink duriluim, not the old ones) $350
OS Giken Cam gears $300
3x Genuine Bosch 044 Fuel pump $200each
100mm FMIC to suit GTR $300
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $40 each
Intake manifold (corrosion on radiator hose pipe) $10
Damaged Thermo Free
Power Steering bottle $10
SMIC with piping $40
Washer bottle $10
Radiator overflow bottle $10
R33 front pair of suspension (pit use) $20
Pair of indicator lights (clear) $20
R33 cat back exhaust (tiny hole in muffler and surface rust) $50
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $100
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
Edited by R32 Driver
  • Replies 42
Posted Images
Hey,
Sorry to be a pain, but do you have any pics of the individual pieces of the turbo kit? I'm thinking of going big-single.
Thanks!
Hey,
Thanks!
Ill take photos of the kit tomorrow morning, however i wont be seperating the kit :)
Thanks for posting pics. Do you know what width the dump/front pipes are? What kind of use did the turbo see in those 4000km's?
Cheers!
3.5" dump and its a dump/front pipe in 1, made out of mild steel
Unsure what the turbo saw during the 4,000kms but Its been checked by a professional workshop b4 purchasing and no shaft play at all (Inspections welcome)
Tomei Cam Gears SOLD
N1 Oil pump SOLD
HKS Timing Belt SOLD
3x 044s SOLD
1000cc Injector and rail SOLD
ARP Headstuds on HOLD
Steve
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
