Hi,
I think its about time i upgrade my brake master cylinder, Im running AP Racing CP5200 calipers on the front. running std r33 gts-t (non-abs) master. I was thinking about upgradeing to the R32 GTR VSPEC 2 master but im not happy to pay over $500 from nissan for a stock item.
I have been looking on the AP website and they sell alot of masters, i was wondering if anyone would be able to put me in the right direction on what would be best for my application and what i would need to make it fit?
http://www.compfriction.com.au/master_cyli...er_cylinder.php
CP2623 - A compact flanged mounted Master Cylinder suitable for all brake and clutch applications especially where the space is restricted. Short travel to cut-off is standard, extra short cut-off also available. 10 bore sizes from 14.0mm to 25.4mm. Hydraulic threads are Imperial.
CP6465 - A new concept in Master Cylinder design. This cylinder operates on the Pull rather than Push principle of other cylinders. It has a built in trunnion mounted needle roller bearings for direct mounting to balance the bar. The ultimate in master cylinder efficiency. Metric threads.
CP6093 - A Master Cylinder suitable for most brake and clutch applications where space restrictions are not a primary consideration. the longer available stroke makes it particularly suitable for some clutch installations. Long thread potion allows the push rod length cut to suit. 8 bore sizes from 15.9mm - 25.4mm. Supersedes CP2293 Master Cylinder family.
CP5854 - A new high efficiency single circuit, short push type Master Cylinder. Fixed through a trunnion system running in needle roller bearings and with a one piston/push rod it offers a significant improvement in efficiency over traditional Master Cylinder designs. Full range of 10 bore sizes. Imperial threads.
CP5855 - A new high efficiency single circuit, short push type Master Cylinder. Fixed through a spherical bearing and with a one piece piston/push rod it offers a significant improvement in efficiency over traditional Master Cylinder designs. Full range of 10 bore sizes. Imperial threads.
https://www.sau.com.au/forums/topic/306780-brake-master-upgrade/
It looks like this is the type i will be after
http://www.apracing.com/info/products.asp?...+Type_2390_2389
Weight 0.31Kg (0.7lbs)
Full Stroke 25.4m (1.00")
Travel To Cut-Off - Short - .68 to 1.09mm (.27" to .43")
Inlet Hydraulic Thread M12 x 1.0
Outlet Hydraulic Thread M10 x 1.0
Push Rod Threads Available PRM = M8 x 1.25 - PRT = 5/16 UNF
Push Rod Length from Mounting Flange PRM/PRT115 - 115mm (4.53") PRM/PRT160 - 160mm (6.30") Other Pushrod Lengths available. Contact Technical Department for more information.
Bore Sizes Available Part Numbers
14mm CP4623-88PRM115 / CP4623-88PRM160
CP4623-88PRT115 / CP4623-88PRT160
15mm CP4623-89PRM115 / CP4623-89PRM160
CP4623-89PRT115 / CP4623-89PRT160
15.9mm (.625") 5/8" CP4623-90PRM115 / CP4623-90PRM160
CP4623-90PRT115 / CP4623-90PRT160
16.8mm CP4623-905PRM115 / CP4623-905PRM160
CP4623-905PRT115 / CP4623-905PRT160
17.8mm (.70") CP4623-91PRM115 / CP4623-91PRM160
CP4623-91PRT115 / CP4623-91PRT160
19.1mm (.75") 3/4" CP4623-92PRM115 / CP4623-92PRM160
CP4623-92PRT115 / CP4623-92PRT160
20.6mm (.812") 13/16" CP4623-93PRM115 / CP4623-93PRM160
CP4623-93PRT115 / CP4623-93PRT160
22.2mm (.875") 7/8" CP4623-94PRM115 / CP4623-94PRM160
CP4623-94PRT115 / CP4623-94PRT160
23.8mm (.937") 15/16" CP4623-95PRM115 / CP4623-95PRM160
CP4623-95PRT115 / CP4623-95PRT160
25.4mm (1.00") N/A
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
