  • Replies 131
Hey just wondering if you got the middle part for the rb25det , so the 2 bolts that screw on and the hose? cheers man
Sorry can't help with these.
  • 3 weeks later...
  • 1 month later...
hi,
I have a dash 10 or a dash 12 for the rb26. As for size it would depend on the catch can fittings or your personal preference i think. The dash 12 is bigger by about 2mm in diameter and will flow a little more.
I think the dash 10 is enough and have not had any complaints with this size. I have had a request for a dash 8 for a rb26.
So short answer i would say its personal preference and also what you are connecting to.
Thanks
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
