  • Replies 93
Is the LINK ECU setup to run your VCT???????
yeah as far as i know the vct is set to kick in at 3000rpm because at 2000rpm it was causing a slight throttle miss fire
i dont know much about the tune part :P
found out from tuner its from 3000 to 6000rpm
Edited by l0WRB
I cant really dump the exhaust and drive around the streets lol and booking into tuner takes forever he always 3-4weeks booked out.
went for another few test/runs last nite from 60-200 hard into 4th , boost drop off between gear changes is horrible it takes so long to build back up and start pulling
could 50mm gate cause this? being to large for the turbo setup?
I have driven around the block before without an exhaust just make sure its a short block hahaha. yes you get a few looks :)
in theory, yes. but we arent talking half the map worth of load dropping off, if the tune is good it would be lucky to lean out anywhere near whats called dangerous.
plus its only for a squirt, ud want to re dyno it after u fix the problem anyhow.
The way i look at it is if the rectriction is causing it to loose 50rwhp, then removing the restriction means there is 50 hp worth more air going through the motor with the same fuelling. 95% time it will be fine for a short squirt, but i wouldnt risk it without knowing whats going on.(but i have a wideband so i have no excuse)
i see your point adriano.
justin, i know disconnecting the VCT will make it slower but the point of the test is to see if the VCT is even working... if you disconnect the plug and it drives exactly the same, uv found a major contributor to the problem
also, going around the block for 1 little squirt in 2nd from a low speed just to see how boost builds wont get you in TOOOOO much trouble. just dont over do it.
this afternoon done a full compression test and came up even across all cyclinders so motor is still fine
tried a different bov nothing changed, tried no bov and nothing changed.
hmm
i might try the vct tnite? see how i go
Edited by l0WRB
little bit of a video from yesterday on a closed road
hard 2 see but can feel the lagg big time between gear changes
havent tried vct yet.. pulling turbo back off this morning and trying a new setup
another vid from other day on closed road
Edited by l0WRB
*Cough* *Cough* Restrictive Exhaust! :P
Driving around without an exhaust is no louder than most harleys. Do you have a mate that lives on a remote road? Go out there, drop the exhaust and go for a quick drive. As said previously just give it a quick squirt and see if it builds boost faster but dont overdo it.
man that kicks in late.... the power is there but its soo late....
seriously try the VCT asap, that seems more fundamental than the cat tho.. even tho the cat might be holding it back abit, for the thing to have nothing till after 5 is pretty rough..
if you havent started stripping it off already try the VCT man
its already been taken off this morning and sent back 2 do some research into it.
going hi mount setup now with different setup see how that goes!
So your going to put a new manifold on without finding the issue? Whats to say that will solve it?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
