oh different skylineimports to the one that contacted me then...
ooo 2 kakimoto replicas...
oh yeah din notice the carbon fibre lip... thoguht kakimoto rims were a given...
  • Replies 72
skylineimports is in QLD
Contact Ernest Parry
Phone  +61 07 3805 7577
Autotrust you should know that, Skyline imports complied your car
heres a 1024x768 taken same time as his car was there (note the white one beside it)
Yeah, I know, I was going to point that out but the CBF factor kicked in, you know how it is. oh and kiss my ass wid ya tongue out!! :aroused:
maybe you should try penis... it seems to work...
gonna have to work on a mod that only censors words if you are a guest or underage... if you're an overage registered user you should be allowed to see all the profanities concocted up by mankind.
ARGH - now MY c0ck isn't working properly - CAREFUL PEOPLE, it's CATCHING!
Ok CHILDREN, :shake: it's time to get back on topic, here is another fine picture of an original Kakimoto.....please forgive me for the choice of file name :rofl:
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
