The only prob is that the tracks rely on a % of the door to actually stay in business.
Due to whatever reasons, there's no other category that draws the same crowds, hence no V8's equals much less money.
Even if after all is said and done, the track walks away with a 100g's profit, thats still at least 80 grand more than they would probably get through regular weekend hires.
On the plus side, maybe on their next OS round, the cargo ship could sink wiping out the entire category in a day.
"uuhhhhh boss..... how many holidays do i have saved up??... i think i might take a few weeks off.... starting from now"
LOL no love in here for the super taxi huh.
Anyways we are one of the support races next weekend in a GT class and i am betting we will be quicker than they are, and by some margin too.
Its a pity and its a blessing, it is a good day out for alot of people, and alot of other smaller business make good money when their here.
It would be nice to see alot of other classes come to WA, were just so damn far away :)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
