So just chasing some advice.
R32 running RB25DET
T04E highmounted.
Car started burning oil.
Compression tested all 6 read around 160
Cleaned PCV still no luck.
tried thicker oil.
Assumed it was the turbo so i had it rebuilt.
Refitted all ok. Car still burns oil and is getting worse.
Disconnected breathers and started engine.
Intake side has no air movement.
However exhaust breather chuffs like a steam train.
Does this sound like valve stem seals to anyone or have a smashed something ?
Car burns oil pretty much from cold driving. more so under boost.
Any ideas ?
https://www.sau.com.au/forums/topic/307447-ahhh-me-blue-smoke/
are the breathers sucking or blowing at idle? one way valve disconnected/blocked when testing?
one way valve disconnected. intake no movement at all. exhaust side blowing at idle.
Also car still pulls hard no miss firing etc etc
Edited by r32pat
sounds like the cross over may be blocked if the intake side seems like "nothing" and outlet is pumping it out...
this is with all breathers disconnected and the exhaust side just venting at idle. so in this case the cross over pipe between both rockers isnt attached.
Note this was only for testing of course.
PCV connected or disconnected?
tried both under driving conditions. no change
Its been bugging me for months. I have a R34 4 door daily and been busy at work so i havent been able to play with my r32 for a while.
So i really appreicate the responses. Its been doing my head in lol.
Edited by r32pat
I'm talking during your test.
Yep tried both during my tests at idle.
i have tried everything you guys have suggested so far in the past with no luck.
I have another engine lined up worse case senario. But who doesnt wanna save some money if its something like stem seals?? lol
Edited by r32pat
  • 1 month later...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
