hey everyone
selling my HKS 2530 turbo kit,
mint condition ( 3 months old)
braided oil feed line
adaptor for stock intake
silicone elbow
3" dump and front pipe
8 psi actuator
after $ 1300 delivered!
pm me.
https://www.sau.com.au/forums/topic/307666-hks-2530-turbo-kit-for-rb20/
its a genuine Garrett GT 2530, exact same as HKS, turbo is still on vehicle can come test drive or hear running ect, makes 200 rwkw on 13 psi with stock everything including computer
cheers!
cheers!
Why r u selling the gt28r? upgrading to a bigger turbo ?
