Then it sounds like the problem that I addressed in the first page of this thread, You need to remove the wheel, boss and all and compare the slot in the boss with the standard wheel and there will be a difference. the sensor must be positioned exactly central on the hole in the boss, and using foam and or tape to fatten up the prong on the sensor worked perfectly for me and many others.
Have you tried this??
sorry buddy i have not tried this yet although im not sure what the hicas sensor looks like.
Ive had the wheel off and im not sure what the hicas sensor looks like :P
Fark............ I just spent 20 minutes replying to this in a funny and witty manner with many references to male and female genitalia included and the whole lot was lost when i posted..................... GRRRRRRRRRRRRRRRRRRR I have to cook dinner now and then work on my car.............:crazy:
Any way the attached pic shows the rear view of the standard 33 wheel. the highlited hole is the nice tight girly bit that the hicas dick fits into...... the aftermarket boss has a larger slot and the dick floats around in it too much resulting in the sensor being off center when you are driving in a straight line.......... so fatten the part that fits in the affore mentioned hole using electrical tape to create a tight fit and bob is your uncle.....
failing that i can explain at MAS if you still don't understand, don't be shy not everyone is expected to be proficient at the art of vehicular modification.. ;)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
