For as long as i can remember ive always had the slightest of hesitations when accelerating from very low rpm. Only very slight
Nothing that alot of people would notice but im very fussy when it comes to the tuning of my engine.
A few people i have talked to about it calls it the 'Haltech hesitation' and something that a few people have, but are not really fussed about.
Adam tells me he has to put a fair bit of filtering on the TPS when he tunes my car, would this be the source of the hesitation problem?
What would the symptoms of a failing TPS be?
https://www.sau.com.au/forums/topic/308062-tps-filtering/
it can be as simple as a timing step just off idle or a lean or rich spot, fairly simple to locate (in a vacant carpark) and it is generally a bit of trial and error to smooth out. It took about 20mins of start stops testing to smooth a sr20 i did awhile back to the point it was imperceptible.
Laptop and a tps vs timing log would get you on the right track to start, when it jerks look for a jump in timing in the log, if there is nothing there start playing with the ms values in the inj map. If that fails look at the accel pump values. I often see too much fuel in accel pump which can also load up the engine so it stumbles.
https://www.sau.com.au/forums/topic/308062-tps-filtering/#findComment-5085826
What would be the reason for the filter on the TPS?
To reduce noise, i have a funny feeling this was fixed in a firmware update by haltech. Try searching their forum as i swear i read something like this about a month ago.
https://www.sau.com.au/forums/topic/308062-tps-filtering/#findComment-5085835
Funny you should say that, i have a custom update from Haltech in my E11 to try and smooth out the hesitation. Worked a little but still there.
I think we will just have to find a quiet spot somewhere and go through the motions to try and solve it.
I wish my knowledge of tuning was a bit better :blink:
https://www.sau.com.au/forums/topic/308062-tps-filtering/#findComment-5085845
I've seen the symptom on various windows based haltechs. Its an accellartion enrichment error that cannot be tuned out. Have seen the issue on constant throttle with acceleration enrichment turned off - if you scope it you will notice asyncronous pulses with a random amount of pulses and pulsewidths. Have sent the scoped data to haltech on two different cars - they havn't been able to sort the issue!
You will also notice that the pulses dont show up in the logs as an accelleration enrichment value.
https://www.sau.com.au/forums/topic/308062-tps-filtering/#findComment-5085930
i get exactly the same problem with my x-trail...
im using an EMS stinger with a MAP sensor, and ive come to the conclusion its from 'noise' in the vacuum line to the MAP sensor.
im gonna try to put a filter/vacuum reservoir in the line see what that does.
Is your Haltech using a MAP sensor for the engine load? or is it throttle position?
i.e. are your sure its TPS related?
https://www.sau.com.au/forums/topic/308062-tps-filtering/#findComment-5085971
if thats your only issue with the stinger you should be happy :blink:
https://www.sau.com.au/forums/topic/308062-tps-filtering/#findComment-5085997
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
