Hey guys i have my awsome computer for sale, reason for sale, i dont use it as i have my work laptop.
Specs:
Intel core 2 duo extreme E8500 (3.5Ghz dual core)
2 gig RAM
RAMPAGE extreme, gaming mother board.
ASUS NVIDIA Ge Force EN9800 GTX (direct X 10, 512mb DDR3, PCI express 2.0)
Supreme FX HD sound card
Super flower 1200w power supply
thermaltake CPU fan
Thermaltake Kandalf case (w/case fans)
BenQ dvd RW
Asus dvd RW (light scribe)
500 gb hard drive
80 gb hard drive
160 gb hard drive
also comes with all the drivers
*no operating system will be installed as i will be wiping the hard drives clean
asking $1100 ono, retail for this will be way over 3k
please call bevan on 0412 054 982 or feel free to PM me on here.
cheers guys
https://www.sau.com.au/forums/topic/308321-fs-great-computer/
  • 2 months later...
^ Yep. 3.16 GHz, 9.5x multi (vs E8400 3.00 9x)
Perhaps it was a mild overclock, could easily do 3.5 on the stock cooler
yea i used the overclock software it came with and with the big thermaltake cooler i have it was no problem
$800 ono !!!
moving house i dont really wanna carry it with me
ill let you know about tthe graphics card if you still want
What is the batch number of the EPU?
What stepping is it?
What brand/model ram?
oh and ill check, i sorry i havent been on SAU for a long time
oh and will consider trades for a laptop, iphone (mine was distroyed in car accident) PS3 games
or toyota paseo after market parts Starting a new project)
Erm you posted the same stuff in another topic with $650 ono.. and now this one is $1100 ono?
<a href="http://www.skylinesaustralia.com/forums/Great-Computer-Sale-Vic-t317255.html" target="_blank">http://www.skylinesaustralia.com/forums/Gr...ic-t317255.html</a>
Look at the dates, the $1100 was from feb, has since been dropped to $800 in this thread and i guess since its an old thread he started a new one with a new price, a bit of reading would have told you that.
Edited by W0rp3D
i have also a logitec G5 laser gaming mouse (black and blue with adjustable weight cartridge) and Zboard gaming keyboard with normal key set and gaming keyset that cam be traded or negotated in also accept straight trades or trade with cash for laptop/note book/ipad with external Hard drive, ps3 games/ equipment or aftermarket parts for my Paseo project.
oh and i still have some stock pipes from my R33 GTR, "Twin turbo" pipe and brand new twin Greedy Airnix Pods to suit Z32 AFM if anyone is interested !!!!
  • 4 weeks later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
