Hi,
So I bought my Skyline about a year ago, as a bit of a project because it was pretty beaten up, and as such I got it pretty cheap. My insurance has been really good so far except that they just insured it at what I paid for it, and not a market value.
Having spent a year fixing it and spending money on it, I wanted to increase the value on my insurance to it's normal market value, or something similar, but I need to get an evaluation apparently. I'm not entirely sure about how to go about this?
Does anybody here have any suggestions as far as getting it evaulated?
NB: I'm not interested in anybody's gung-ho "f*k InSuRanCeZ mAn U dUn NeEd ThAt ShIz" ideas.
Cheers,
Mods: Sorry if this has been covered, couldn't find anything searching.
https://www.sau.com.au/forums/topic/308437-insurance/
Hi,
Cheers,
Hi Tim
You need to go to a dealer to get a valuation from them and some dealers will charge you for it as well.
If you know a dealer (preferably one that sells Skylines) then maybe they can help you.
If you know anyone at C-Red then they may be able to help as last time I checked they had a Dealers License.
Hope this helps
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090225
Cheers,
Thanks Rod, I'll be looking into that when I get home. Just out of curiosity, what do people think the market value actually is? I saw a completely stock 33 [i think this was actually less than had come out of the factory, had lots removed] for for 15k a few months ago.
Thanks for the help
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090383
The ol' "mildly modified 33"? Reasonably good nick.
Was more interested in the market value that insurance companies will be going with like Kaido is talking about.
I renew my insurance in in dec 09 and Just Car had the market value of my r33 gts-t S1 1993 at $11,000 :P
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090470
Any luck with this Tim? I am wanting to do the same thing, i am with JustCars as well and they will only insure my car to $10000 :/
But after i do the engine swap then i will want more cover than that. What other companies insure gray imports? Shannons won't insure me because im under 25
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5094248
When I swapped my insurance from just cars to sgio they said they could do it at market value which was 10k or what I paid for it which was 8.5k, so mine is insured for 10k even though they know i payed 8.5k for it over 6 months ago. This was for third party fire+theft btw
Edited by Crackfox
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5096723
My car was insured with JC for $2k (car value $10k), when I came to renew the policy early this year I used their website thing & added some of the extra mods I did to the car (exhaust, POD, SAFC 2, intercooler & boost controller) they upped my car's insured amount from $10k to $11.7k & didn't change my premium? Are they actually being generous or their computer software must be bugged?
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5104351
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
