as long as they are legal rims with legal tires it wont be a problem in changing them. best to let the insurance company know about it though, if your ever in an accident and they dont know about the new different sized wheels, they will argue that they could have been the reason for the accident and refuse to cover you. :) the worst that will happen by telling them is, they may not cover the entire value of the rims if they are damaged or stolen.
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5096685
Yeah you are always better off telling them. An extreme example is a friend of ours had a heavily modified beetle, pulled up to a stop sign and had a postie run into the side of him on his bike. Instead of pay for the damage, Australia Post paid an engineer to go over his car and look for a way out of it. They found that he had re drilled discs on it, which is pretty much essential to run a nice set of wheels on a bug, and argued that the car was un roadworthy. Because of that he had to pay for the hospital bill for the postie and was out of pocket for his car even though he wasn't at fault.
So definitely tell them :)
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5096690
if ur with just cars they will put an extra excess on for your wheels. so it doesnt affect your normal premium just has a seperate excess
did this with mine, and its just a $300 excess or something, and my wheels are pretty expensive
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5097167
it is so much safer to tell them all. I had my 180sx stollen last year and cause I had changed the mags without telling them (i put a cheaper pair on for a cruise) they bailed on the insurance altogether and didnt cover a thing. was so not cool.
so yeah I would tell them.
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5108643
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
