as long as they are legal rims with legal tires it wont be a problem in changing them. best to let the insurance company know about it though, if your ever in an accident and they dont know about the new different sized wheels, they will argue that they could have been the reason for the accident and refuse to cover you. :) the worst that will happen by telling them is, they may not cover the entire value of the rims if they are damaged or stolen.
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5096685
Yeah you are always better off telling them. An extreme example is a friend of ours had a heavily modified beetle, pulled up to a stop sign and had a postie run into the side of him on his bike. Instead of pay for the damage, Australia Post paid an engineer to go over his car and look for a way out of it. They found that he had re drilled discs on it, which is pretty much essential to run a nice set of wheels on a bug, and argued that the car was un roadworthy. Because of that he had to pay for the hospital bill for the postie and was out of pocket for his car even though he wasn't at fault.
So definitely tell them :)
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5096690
if ur with just cars they will put an extra excess on for your wheels. so it doesnt affect your normal premium just has a seperate excess
did this with mine, and its just a $300 excess or something, and my wheels are pretty expensive
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5097167
it is so much safer to tell them all. I had my 180sx stollen last year and cause I had changed the mags without telling them (i put a cheaper pair on for a cruise) they bailed on the insurance altogether and didnt cover a thing. was so not cool.
so yeah I would tell them.
https://www.sau.com.au/forums/topic/308842-insurance/#findComment-5108643
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
