Hey all,
I have for sale my R33 4 door. Its an Impul built 94 model.
Features:
Engine/managment/Induction:
Rb25det Manual
Vulture motorsports greddy copy plenum
Power FC with hand controller with boost controll kit
FMIC
Knock off HKS ssqv blow off, also have a plumb back attachment for it
Bosch or siemens (cant remember) 740cc Injectors (not installed)
Brand new Exedy sports tuff clutch (not installed)
KKR480 (not installed)
Turbo back 3 inch exhaust system
Short shifter
New alloy radiator with 12inch thermo run by an "Ice" adjustable thermostat
New water pump
Interior:
Impul adjustable bucket seats
Impul steering wheel and gear shifter
Smoke face boost and oil temp gauges
Sony double din dvd player
Clasrion front splits
New leather gear stick and handbrake boots
Exterior:
17 x 9 Impul lightweight alloy wheels
Cant remember what tyres but they are fresh with plenty of life left
Full body kit
Gun metal metallic paint (needs attention)
I am selling because my house has just started getting built and it has come to my attention that I need MORE MONEY ASAP!!
The paint has the clear coat peeling off and the front bar is stonechipped. Needs attention to get it back up to a high standard.
I am open to swaps and cash sales. Swaps for something like a datto 1600, turbo utes, rotary utes etc etc
I would prefer cash but show me what you have got! the pics are a lil old but it still looks the same.
$11,000 negotibale. Located in Gympie, 1hour north of maroochydore. I am prepared to travel if it helps you out with the sale.
If you want to contact me you can ring 0439709299, on here or [email protected].
Edited by M3ld
https://www.sau.com.au/forums/topic/308863-r33-4-door-imul-built/
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
