WRECKING 1995 R33 S1 GTST MANUAL, MAROON
LEFTOVER PARTS FROM A WRECK
x4 doors 4dr $50 each complete
x6 window regs and motors $50 each
front and rear seats $100 set
dash complete $150
cluster auto $100
x8 seat belts $50 each
bonnet silver(small bend in rh corner easy fix) FREE
bonnet maroon perfect $100
headlights $100 each
rh 4 door tailight $50
passenger side door 2dr $100 each
grill $50
gaurds x4 $50 each
side indicators x4 $50 pair
front indicators x4 $50 pair
passenger window switch $50
rear window switches $30 each
door windows $50 each
mirrors x4 $50 each
rear floor mat 1 piece FREE
overflow bottle FREE
washer bottle FREE
ac condenser $50
power steering rack $100
front k frame $150
rear k frame x2 $150
front castor rods $50 each
control arms $50 each
struts and springs $200 pair
front calipers $200
front and rear discs $40 pair
front and rear hubs $100 each
rear calipers $150 pair
x2 auto tailshafts $50 each
manual tailshaft $150
fuel tank $100
drive shafts $70 each
diff manual $200
stock afm pink $100
climate control box $50
boot lid $100
tail lights $100 each
series 1 used coilpacks $100 set
series 2 used coilpacks $100 set
series 1 new jjr coilpacks $500 set
MAKE AN OFFER I NEED THIS STUFF GONE!!
PLEASE PM, SMS OR CALL 0424144636 LOCATED IN EPPING MELB
Edited by myr33wpn
  • Replies 40
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
