Hey Guys,
For sale are parts listed below which have come off my car as im continually upgrading to bigger things!
Any Questions please dont hesitate to contact me
Pictures to follow,
Standard 6 GTR Injectors – One in need of rebuild - $200
Standard GTR fuel Pressure regulator - $80
Standard GTR fuel pump $50
Bosch 040 Fuel Pump - $100
Standard GTR oil pump - $100
Standard GTR ECU - $200
Standard GTR Coil Packs - $100
Coil Pack Looms GTR - $60
Standard GTR cam gears - $50
Standard GTR ceramic turbos - $400
GREDDY Intercooler 70x30x100 - $500
2 Pod Filters - $100
ARC R32 GTR airbox - $400
11 row 17x24cm oil cooler - $100
GTR Original cam cover - $150
Original GTR Fan - $20
Standard GTR calipers and rotors - $350
OS Giken twin plate clutch – in need of rebuild - $200
2 x Blow off valves - Aftermarket - $60
R32 GTR standard exhaust - $150
Mines Titanium headers GTR - $500
Titanium cat back GTR - lemon sliced - not sure what brand - have to check size - $500
Exhaust Elbow – Multi angle – 10cm - $20
2.5 inch Catalytic Converter - $50
Exhaust muffler insert – $20
Titanium De Cat Pipe – $60
HKS Boost gauge - $100
Nardi Signature steering wheel - $200
Edited by josh23457
https://www.sau.com.au/forums/topic/309125-massive-gtr-others-clearance/
  • Replies 48
Re the Titanium cat back GTR, could you please advise size and what it suits
Cheers
il have to check tomorrow night but memory i think its 3inch at the cat then swells to 3.5 inch right through....
What size are the collector on Mines Front Pipe.
If it's 3.5" I'm mega keen on them.
Cheers
Grant
hey,
they are 6cm at the dumps and swell to 7.5 at the collector before the cat...
can send you better pics if you send me your email address..
josh
CHecked the ti exhaust tonight
The size of the ti catback is a 3.5inch decat which then straight after goes into a 4inch straight through
the front pipes are 6cm at the dumps and 7.5 at the collector when they go into the cat....
hey,
josh
Crap, was hoping for 3.5" to match my HKS 3.5"
Thanks anyway.
Cheers
Grant
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
