Wanted: Genuine R33 GTR Dash Cluster
Guest RedLineGTR
I am looking for a Genuine R33 GTR Dash Cluster has to be in very good condition everything must be working all dials lights etc. Looking for someone in the Melbourne area if possible (would rather be able to inspect the dash before purchase).
If u have one avaliable please PM or email me with a price and also what year gtr it came out of (or is still in). Cheers Rob
https://www.sau.com.au/forums/topic/30914-wanted-genuine-r33-gtr-dash-cluster/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
