Hello All,
Geez its been a while since ive been on here.. anyway here goes...
Forgot to add this (its a 2001 Stagea RS4S - Manual) 2.5lt neo engine
I took the car in to Pedders today to get a suspension check as having a wheel allignment and balance done didnt fix the shake in the steering wheel. Here is what was found.
Shocks - Front - Fail!! - Soft, Lacking control (recommend replacement)
Springs - Pass
Bump Stop - Pass
Strut Mount plates - Pass
Lower ball joing - Pass
Lower control arms and inner bushes - Pass
Upper Ball Join - Pass
Upper control arm and inner bushes - Pass
Radius rod and bushes - Pass
Leading arm and bushes - N/A
Outer Tie Rod ends - Pass
Sway Bar Bushes - Pass
Sway Bar Links - Fail - Ball Joint worn
Steering Gear - Fail - RACK and MOUNTS WORN (NEED REPLACEMENT)
Power steering pump - Pass
P/S lines/Belts/Filter/Oil - Pass
Wheel Bearings - 3 pass 1 Fail (Passenger Rear)
Tyres - Fail (Uneven Wear OUT OF ROUND)
Shock Absorber Travel on the Front left = 45mm and on front right = 33mm... (Should this be like 20mm????)
Now what i am after, seeing as i am located in Launceston Tasmania, is where i can get some of these parts??
Does anyone know what price i would be looking at and what i should get genuine etc.. (i rekon - without having checked yet that a genuine steering rack would probably cost BILLIONS... But like i said i have not checked yet....
Any suggestions for type of parts? i.e. Aftermarket or factory?
The car is predominantly used by my wife for karting the kids around and so on... So i am not really after some hardcore suspension set up. But i did get told that if i was to get they guys at pedders to source the items for me i would be looking at 3-4k. And frankly i dont have that kind of $$$$ to just hand over without consideration..
Any help would be greatly appreciated...
Thanks in advance
Ben
https://www.sau.com.au/forums/topic/309179-suspension-woes-need-some-guidance/
Hey mate, first of all try a second opinion. You might be pleasantly surprised of the outcome. Second not sure about the rack but I just replaced my rack rubber mounts this morning. I got polyurethane ones from super pro. I have a RS4S 98' so should be exactly the same. Part number is SPF2681K $40. Got them through Fulcrum Suspension, I found they were the cheapest which I found out is because they own Super Pro! Took me about 2 hours to do it. Not to hard to do, just a little bit fiddly.
Regarding the suspension i'm going through the exact same thing at the moment too. Im going with bilsteins but they should be able to get you OEM for cheaper if you cant spend the cash.
Thanks a lot for that info reiseva.... Good to know, and i will probably end up getting the rack mounts from them. I will also post something in the WTB section but as i am here right now if anyone knows how much i would be looking at for a steering rack for a 2001 Stagea or has one for sale let me know via pm please...
Hello All,
Springs - Pass
Bump Stop - Pass
Thanks in advance
Ben
hey mate um i have a mate that brought a half cut of one and he would have a steering rack and mite have a couple over things do you want his number ?
As said the rack mount bushes are cheap and easy, the front sway bar ball joints you can get from nolathane i beleive, around the $150 ish mark from memory.
Front shocks wont be to hard to get, or a rear wheel bearing.
Are they sure the rack is stuffed? Might just be the excess movement from the bushes and or tie rods?
2nd opinion for sure.
I will get a 2nd opinion on monday from Jaxx here in launceston however i dont really know where else to go. Here in Launceston there is Pedders Suspension and a few tyre shops, but Pedders is the only real suspension place that there is that i can think of... I suppose i could go to RACT or Midas or something aswell... Not much choice around here... I will also look into the parts needed, i have got a rear wheel bearing through Tas Driveline. They said the latest ones they have are for a C34 Stagea from 99. So i hope that they are the same.... I know nothing about them... Hope it fits...
On the suspension side of things, the main thing that i want is for it not to be rock solid like my old skyline... i am after a factory feel. but if i can get that with some coilovers then i might consider it... Does anyone know anything about the pedders sports ryder Coil overs? i got suggested them, but for the price i dont know if Tein ones or Blistien ones are going to be better/worse.... I am looking for build quality and ride comfort...
Thanks for all the replies..
hey mate i'm in lonnie and have an rs4s too
there is a guy that works at the new autobarn who has a silver rs4s too so if you need to order parts i would consider using him
as for suspension you could try and source some new front shocks and get a suspension place to install them (same as r33 gtr up front, back is similar but differently valved) or look on ebay at the bc (buddyclub) coilovers
someone recently installed them in his m35 and said that on the softest setting that they were just a bit firmer than stock
if you want to diy the install i could give you a hand (i'm a pro at car park repairs lol, currently changing a mates rear wheel bearing on his bmw in the utas carpark)
for recommendations on where to go for the rest i would recommend signing up to boostcruising and ask in the tasmanian section there for who to go to or ask on the tas section on here but its a bit quiet
Thanks for the tip... I might have to give you a msg some time.. we can have a compare and contrast... and i will go down to Autobarn and have a look. Thanks again
That would be me :D .
BTW, BC isn't short for Buddyclub in this instance. My BC's are the "BR" version.They are a fair bit firmer than stock, (or at least my boat spec, worn stockers, which NM35's seem to be renowned for) but they definitely aren't harsh and crashy over bumps and rough roads (of which, I drive on a few), just well damped and nicely controlled.
Mine have been in for nearly 2 months now, and I have had no issues at all, if anything, the suspension deflection over small bumps (i.e. pockmarked roads) has actually improved, so the ride is actually more supple than when first installed.
In my opinion, they perform better than a "budget" coilover kit has any right to :blush: . I can only recommend them, based on my experience so far.
its really unlikely the rack itself is stuffed, but there are both inner and outer tie rods that do wear. I would strongly suggest changing the inner tie rods and see if that fixes it all up - these steering racks have this wierd nylon bush in them that wears over time.
gday there
you mentioned thats you where going for a second opinion, good choice as i took my car to pedders a few years ago and they did the same something, gave me a list of things thats needed replacing, I didnt bother getting any of it done except for the front shocks which is what i took it in there for, then took it to flemmings for a wheel alignment and asked them to check it over and non of the things they said, needed replacing,
the only places i would take the stag to is
Ron's auto
Boost
Flemmins (not sure on the spelling with that one)
chees
gday there
Ron's auto
Boost
chees
are you the guy that works at the autobarn?
i've heard a lot of ppl on boost complain of poor workmanship at boost, i dunno who to believe :D
yeah it gets like that, i think the only way you will find out is if you go there your self, people can only tell you what happened to them and most of the time they make it out a lot worse than it was!
I have only got tires and 4 wheel alignment and car inspection there, they seemed to know what they where talking about, Rons Auto is where any work gets done on the stag.
and no i am not the guy from autobarn, iam the guy from o'brien auto
cheers
cheers
o'brien auto as in the windscreen place? if so, how much for those chip repairs? cos i got a couple when i drove down from qld
thats a bit crazy that there are at least 4 manual stags in lonnie!
sorry for hijacking this thread so much, but we should have a meet up while the weather is still nice
tassie is the place to be, yeah i think we have gone off topic a little LOL,
I will find out the price for you, they are norm $124 for the first and $70 for everyone after that, or get insurance to pay
anytime you are keen to meet up just let us know, even just a meet and great
sounds good, the gc meet and great was good so maybe a tassie one is in order too
may also involve some "fun" driving seeing as we have such awesome roads down here - you may have to show me your favourite routes
gday there
Ron's auto
Boost
chees
Hey Richo, Where is Ron's Auto? I should go and check them out... I didnt know you were on this forum... nice to know... if i dont get a reply i might send you a txt....
hmmmm i wonder if you know who i am..... :D
hey hey ben
whats happening? Rons is in behind burson's,
48a fredrick st
its funny its hard to tell who is who on here, i could be talking to some one that i probably all ready know lol
hey hey ben
48a fredrick st
Thanks for the info mate, i rekon i will swing by there tomorrow and have a chat... see what he rekons... Sarah might be getting a company car soon which means the stag might be able to get a few perks.... will have to see,... got to fix a few things first
