lol... that's 2 days to work and back for me!
I dunno how you put up with it mate
Are you driving in stop start traffic or highways? On my way to the snow last year I got down to 10-11L/100km, but in the city my consumption is north of 17L/100.. I tried out Shells premium 98 last week. around 20L/100 pinch.gif Lucky I had one of those discount barcodes for it. Back to BP!
  • Replies 234
Posted Images
bit of both(well its on stands at the moment)
its coz i have the emanage installed with a base tune to get me from a - b.
so its running rich as!
Only marginally less efficient than my car :P
I need to put more KMs on mine after an ECU reset.. have to learn it back in for another couple of hundred KM -which should lean it out slightly. Then emanage to take care of the rest ph34r.gif
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
