Had a look at my suspension after rumours that it can be lowered as a standard feature.
I have a set on bilstein struts in there and they have grooves for the spring seat to be lowered. How exactly is this done? Is there a DIY thread for it that I cant seem to find? If not I may type one up with pics if and when I lower it. It seems like i can lower it about an extra 30mm. Should be enough to satisfy me.
https://www.sau.com.au/forums/topic/309692-lowering-stock-260rs-suspension/
Haven't done it myself got shock shop to do it and then alignment but its probably easier to pull them out and then you may need a spring compressor. Posssibly someone here has done it without pulling them out?
My current ride height (bottom of guard to wheel centre) is 340 front 350 rear.
Check out Sydneykid's suspension thread, (stickied) All the info in there.
Cheers GW
PS: Bilsteins are not standard on Stagea's so suspension has already been changed, probably ride height has been optimised at the same time?
Edited by 260tech
Yeah, I gathered the Bilsteins werent stock, i meant in the way that its still stock setup, not adjustable coilovers etc etc.
I'll go have a brouse through all the pages and see what I can find, cheers :blush:
