hi guys im looking for some sizings of intercoolers i dont have to modify my car to fit nicely behind the front bar of my R31 ,
if anyone has one in their 31 with none or minimal mods can you let me know pls , not worried about the piping as i have high mount manifold so will have to most likely do a custom pipe work ...
any info would be greatly appreciated guys and girls
festaonline
https://www.sau.com.au/forums/topic/310119-r31-intercooler/
been told by word of mouth that a 600x300x76 owuld go greatly in the front , just need to figure out how to solid mount it so nothing will manage to dislodge or damage the bottom of the cooler here with the shitty potholed roads that townsville has a great number of lol
https://www.sau.com.au/forums/topic/310119-r31-intercooler/#findComment-5110579
well the ac and all components relating have been removed already , had an issue with the condensor and didnt wanna pay for another so removed it and the all pieces behind radiator so i might just have the room :down:
https://www.sau.com.au/forums/topic/310119-r31-intercooler/#findComment-5111034
ok peeps looks like im going or the 600x300x76 it is , i have had the most feedback about that size and as i dont have the ac at all i should have plenty of space and maybe even make a shroud to direct the airflow to where i need it also i have a few ideas floating in my head just nothing to practice on yet lol thanks for all your help guys and gals appreciate it immensley
https://www.sau.com.au/forums/topic/310119-r31-intercooler/#findComment-5115423
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
