Earlier today, the fat PS3's crashed "millennium bug" style.
The known issues are:
- Clock/Date reset to 1/1/2000
- No access to PSN
- Games with trophy support may/will not work
- Games purchased through PSN may/will not work
- Dynamic and some other themes are listed as "corrupted data"
The slim PS3's did not get affected; only the fat PS3's. Sony have yet to come up with a fix for the problem but have addressed it. It was rumoured that someone hacked PSN and introduced a trojan but that has since been denied by Sony.
Unfortunately, no COD for a while :down:
  • Replies 41
Yer was just about to post this. Got home onto my PS3, insert COD-MW2 cd and right as i was about to hit resume game, i get this error:
Registration of Trophy Information could not be completed - (8001050F)
I'm thinking f**k, which mongrel was f**king about with my ps3. Format the system and restore all defulat settings, still no luck. Googled the error code at the end and found out it was a gobal problem.. pheww
Official announcement from Sony
Some consumers are experiencing a network connection failure when signing into PSN and may receive the error code 8001050F.
We are aware of this issue and it's currently under investigation however at this time there is no estimated time to fix. Please refrain from calling your local PlayStation call centre and keep watching this space for further updates...
Edited by Barbarian
PlayStation Network Status Update
Posted by Jeff Rubenstein // Social Media Manager
We’re aware that many of you are having difficulty connecting to the PlayStation Network this evening. Those of you with “slim” PS3s (the 120/250 GB models) appear to be unaffected.
Know that we have narrowed down the issue and have engineers working to restore service even as you read this. We apologize for any inconvenience this may cause you, and genuinely appreciate your patience while we work to resolve this.
Quote:
Well the gist is that the ARM SYSCON CPU that is used to power up the front panel of the ps3, that is responsible for doing things like sleep mode, eject, RTC etc. Is an old batch that sony picked up from the shelf like other manufacturers that has that calendar year bug regarding feburary 29th on certain periods. Causing the ps3 system clock and the real time clock to desync, messing up security measures like Digital Rights management software and sometimes games that relies on clocks for whatever reason. As well as signing up to the playstation network... This CPU is always on even when your PS3 isn't even plugged in.
This problem is also happening with various of test Ps3 models, particulary the ones that has the emotion engine cpu/gpu for ps2 dev.
This is the one of the same type of CPUs that is powering up mobile devices like zune and blackberries, they have been affected with this bug, so they done some software patches. A syscon update can also fix this problem
The Slims ps3s aren't affected because they use a newer up to date revision on the syscon cpu that fixes this bug.
A quick way to fix this is to remove the RTC battery for at least 5-10 min and plug it back in, you will see the date and time reset, and voila...
found this here
Yep, somewhat of a pandemic, lol, i hope that trophy data isn't lost for good, or im sure heads will roll...
Here is the official word from Sony atm
http://blog.us.playstation.com/2010/03/lat...network-status/
and both the European and US sony twitter accounts
http://twitter.com/PlayStationEU
http://twitter.com/SonyPlayStation
So we're being told to not even turn on the PS3 until the problems fixed...
damn and I was right in the middle of Uncharted 2...
Well chances are you wont be able to play it anyway due to the trophy sync error, i can't play any of my games due to this, but demos work fine
So i'm guessing the older games will work?
so no Dante's inferno, bioshock 2 or uncharted 2 for a few days...
F**K Pull your head in Sony!
all is well now, although if you were unlucky enough to try and play any games while the ps3 shit itself, pretty much the whole of the 1-3-2010 then you most likely lost a whole heap of trophy data *sucks*
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
