do you have a gtr for sale? im in the market for one, i want a stock one with no mods, but i will consider anything not too modified, it needs to be streetable. do you know somebody honest that can import one for me? there are plenty out there with the dealers, but i dont trust dealers. from what i heard most of the wind back the clock, so how do you know if its been wound back or not? do you ask for the japanese auction papers?
who is trustworthy out there?
what would your shopping procedure be for one of the beasts?
i still want one guys, $$ are ready to go
95, 96, 97, or 98 must be clean inside out with less than 80k on the clock
you can contact me and we canl arange an inspection..
0404 301 881
  • 2 months later...
0404 301 881
Hey mate ive got for sale my R33 GTR FOR SALE very clean n very well look after all inspections are welcome
Im also from sydney
Motor is stock no major work done
Have my 1995 NISSAN SKYLINE R33 GTR vspec. up for sale.
148,000kms. hardly driven just on weekends. 5 speed manual. rego untill October 2010.
MANY EXTRAS TO LIST
WALBRO FUEL PUMP
EXCEEDY HEAVY DUTY CUSHION PLATE CLUTCH
BOOST TAPPER
20 INCH LENZO DEEP DISH RIMS
GREDDY ADJUSTABLE CAM GEARS
CRUISE CONTROL INSTALLED
FRONT MOUNT
SHIFT LIGHT
CAR HAS BEEN REGULARY SERVICED AND BEEN LOOKED AFTER VERY WELL IT DOESNT MISS A BEAT.
CUSTOMISED NUMBER PLATES (33ZILA)
Offer me a reasonable offer if interested
  • 6 years later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
