Does anyone know what the maximum power limit of a standard RB26DET con rod is? At what point do they stretch/bend?
I have been offered a set to put into my RB25DET engine as an upgrade. So I need to know whether it's worth it.
Also you guys talk about Linished rods. Can someone explain what that is please?
Cheers Fellas :P
https://www.sau.com.au/forums/topic/31078-power-limit-of-rb26-rods/
I am told by relable sources and have seen GTR's make 450rwhp + on standard rb26 rods.
I am currently building a rb26 and not sure yet whether to upgrade the rods or not. I think it would be more for security. And with the forged rod been lighter it should revv a bit more freely as well.
I can say from a hands on experience that rb26 and rb25 rods are world apart. they have different shape beam the egdes are different also thicker and the most important of all is that the rb26 rod carry a masive bearing end as comparo to an rb25. As for power capacity is all depends on how well u tuned it. But big numbers have been recorded.
Merli, one place that comes to mind is http://www.skylinesaustralia.com/forums/sh...ead.php?t=28130
Steve-SST, who has played with many RB25s and RB26s, is quite adamant that they are the same in most cases, just some RB25s came out with weaker rods, but it appears from his posts that most had the same rods as RB26.
Very interesting read!
I suppose it's quite possible, as all RB25 failures I've seen from excessive power levels have been piston related, which THEN leads to the rods punching holes through the block.
I'm not so sure about the claim that "but some RB 25s have weaker rods but a lot have GTR rods" though... That just seems very iffy and unlikely to me.
Either they all have the same rods or don't. Or all Series 2 and on have RB26-spec rods, or something like that. The claim of:
The only real way is to pull it down but some RBs respond very well to boost upgrades-Exhausts etc and some don't, the ones that don't tend to be the dog motor as the head flows less.
seems like it's based on not enough evidence to me, and based on one or two RB25s grenading and resulting opinion that it had "weaker rods than the rest" and was a "dog motor"
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
