An oppurtunity has come up to get an rb25 block with crank, pistons etc all still there. Im throwing up two ideas, trying to put the rb25 bottom end in instead of the rb20 bottom end or using rb25 internals in the rb20 block. I've done a few searches but information is very slim. Can anyone add some light to the situation??
Cheers
Jayson
https://www.sau.com.au/forums/topic/31083-rb2025-combo/
that's a real pain, Any ideas about putting an rb25 block and internals in replacement for the rb20 block? With the 2.2 L did he just bore it out and put bigger pistons in??
Thanks mate
You wont be able to bolt the RB20 head onto the RB25 block without causing yourself a bunch of heartache. If you can get the RB25 block at the right price, you may consider getting an RB25 head and just going down that path.
Yeh, the RB22 is just bored out RB20 block.
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-628718
Hi Mase, here's the go................
Use the RB25 crank and rods and set of standard 4AGZE pistons, that gives you 2.3 litres. The last set of used 4AGZE pistons I bought cost $100 for the set of 4, so $150 for 6. New set of rings was $20 per piston (AGE's are as common as). Balance all the up & down and round & round bits while you have them out.
Sell the RB25 block and pistons, you'll get most of your money back.
Stick a set of standard GTR camshafts in it (they are cheap), adjustable pulleys and with the right turbo it will fly. I have seen 260 rwkw out of this combo, with a good spread of power across the rev range. Unlike a standard RB20, which at 260 rwkw is very peaky.
Hope that helps
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-634396
So the RB25/26 rods small end and 4aGZE pistons rod bushing/piston pin match up ok and also the piston height works out ok.
For every time i have read they bolt straight in i have read or heard that the piston pin needs attention or the piston requires machining of the head to ensure correct height???????
If thats the case id rather get forgies, sure the casting process of the 4AGZE offers improved strength over most other cast pistons, and i have also read that the 4AGZE (supercharged vs the 4AGE NA) pistons also have a form of ceramic/ treatment std, in which case any maching of will only further weaken the piston??????????
ALL SPECULATION AND THINGS I HAVE HEARD. If i had the bankroll i would love to go and find out for general info as much as my own sake. ;)
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-634587
Depends on how far you want to go, how much DIY etc etc.
But for a reputable workshop to do the whole hog, you would be looking at $15k. Thats:
- Remove RB20
- New quality bearings/studs
- Purchase of 2nd hand RB26 rods and crank
- Forged pistons to suit your desired compression
- Increase the daim of the combustion chamber to suit 83mm bore
- Re-co of head, (Perhaps some new valves, valve springs and cams, GTR like Sydneykid suggested)
- The engine is being completely stripped so new gaskets
- NDT of block, crank, rods
- General machining/decking
- Balancing bottom end
- Re-assembly of engine
- Install new engine
Consider that many workshops charge $70+ an hour and you can see why it gets so expensive. Do much of the running around, do the nuts and bolts stuff yourself and you can save thousands...best to do your own numbers after talking to the people your comfortable using to do the work.
Your doing well to have it done for less then 6K
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-635103
Hi Roy, I'll try and answer a few of your questions...
^ 4AGZE pistons require no machining to fit
^ I believe they are high pressure cast
^ The crown is ceramic coated
^ The skirts are coated with oil retention compound
^ The 4AGZE gudgeon pins fit the little end of the RB25/26 conrods, with very minor machining of the bronze bushes. This is normal stuff.
^ Ceramic coatings is applied to the crown as a heat barrier, it has no effect on the strength of the piston
^ All of the block machining and balancing similar to what you would have to do to make a 2.3 litre RB20 cost me less than $500.
^ Lots of RB30 (Commondoor) parts fit, made by Nissan sold cheap by 'Olden. Think gaskets, seals, water pump, oil pump, bearings etc
So if you can do the engine R&R and the assembly, it will cost less than $5K if you have to buy everything. If you have some of the stuff it will be even cheaper.
But Roy is right, if you have to pay someone to do it, you might as well do an RB31 because it will cost the same. For example a set of 82 mm forged pistons will cost the same as a set of 87.5 mm forged pistons. Balancing an RB30 crank costs the same as balancing an RB25 crank, etc etc.
So as much as I would like to build a 2.4 litre RB20, bottom line is I can build an RB31 for about the same. That's why I haven't done one......yet...
Hope that helps some more
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-635425
Thanks Sydneykid, most helpful as always.
Just trying to be realistic with costs, as i suspect too much 'buck-fitty" stuff is posted here, and hate to see someone start down this path thinking it was a cheap option.
The dollars soon add up, main reason i am hesitant of building such an engine is that i would want to do ancillaries as well, so things like GTR oil/water pumps, better valve springs, bigger cams, to ensure that the thing can cope with sustained 8,000rpm track work. Which always makes like you said the RB31 option better, especially considering the flow benefits of the RB25/26 heads and ability to get away with lower rev limit.
Then i sit back and sure the power i have may be a bit peaky at the moment, but its still fun and its not like i do any competitive stuff with my car, my track days are purely "therapy" sessions so as long as im having fun which my car ....that said if i had the surplus coin i would do it all in a heartbeat. ;)
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-635801
rb25 block $250 for me
I have an rb20det
pistons 4AGZE say $200
maching 20-30 per cylinder. worse case $180
new rings $120
Bearings $100??
blueprinting roughly $200
New headgasket (metal) $200
All labour is done by myself and a mate. My mate has done the rb30/25 to a mate's r33.
The other stuff like cams etc can be done at a later date right?
This is worse case scenario.
Then, i can sell rb20 crank and rods, good rb25 block and rb25 and rb20 pistons.
Thankyou very much for your help sydney kid, straightened up a few things.
https://www.sau.com.au/forums/topic/31083-rb2025-combo/#findComment-636171
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
