1998 R34 GT-T
Its done 95,000k's still drives fantastic, never been boosted, serviced every 5000k's with mobile1.
Features:
  • White Buddy Club SF rims; 18x8.5 front, 18x9.5 rear
  • fugitsubo 3" cat back exhaust
  • 3" JJR front/ dump and high flow cat
  • RSR Coilovers
  • Whiteline camber kit
  • Poineer USB headunit
  • Pod filter
  • Blitz turbo timer
Very little scratches and no dents or panel damage.
Tidy car inside.
Looking for 20k ono.
I Live in Newcastle so send me a message or call 0431987566 after about 4 if your interested.
I'll put up some more photos soon.
https://www.sau.com.au/forums/topic/311160-1998-r34-gt-t/
Just spent two months trying to sell mine - quite a few more mods and no one is even interested in it for $17k. :)
I've given up it's not worth the loss of $$!
Good luck with it though...!
Sucks bro.. looks like ill end trading it in haha.. bummer too
https://www.sau.com.au/forums/topic/311160-1998-r34-gt-t/#findComment-5155634
  • 3 weeks later...
  • 8 months later...
  • 1 month later...
  • 4 weeks later...
Yeah it took a bloody long time, had it on drive.com and only got spamers there, such a waste of 40 bucks haha, had more interest on here which is no surprise, tho heaps of people wanting to trade :s.. sad to see her go but the buyer will look after her :)... I hope lol
https://www.sau.com.au/forums/topic/311160-1998-r34-gt-t/#findComment-5745939
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
