Posting on the behalf of my brother.
2007 Nissan 350Z Track, New Model, 230Kw, Limited Edition solar metallic orange.
Second owner, purchased from elderly couple who had taken delivery of a new Audi A4. Selling to upgrade or maybe to be wise and buy real estate ;-)
350z is in perfect condition inside and out. Inspections / testing welcome. Showroom condition.
· Top of the line 2007 Track Model, new shape-final 350z series
· 16,500 KM
· Full 12 months Rego (Oct 2010)
· First Registered Aug 2007
· Genuine Nissan Factory warranty till August 2013 (paid for 3 years extra)
· Complete service history with log books and papers (Genuine Nissan)
· Always garaged – never parked in the sun!
· Recently completely detailed – mirror finish.
Accessories included
· Standard options like Brembo Breaks, Bose sound, leather heated seats + more!
· Factory Tinted
· Reverse parking sensors, factory option, a must for this car!
· Z floor mats
· Garmin GPS professionally installed into centre dash compartment. Remote antenna, instant connectivity and works in CBD!
· Custom Plates MYZ-350 included.
Never abused or thrashed, evidenced by original factory tyres which are still on the car.
No test pilots! Located in Homebush area.
Asking Price: $52,000 $49,000
Call for more info
Kav: 0422 286 206
Edited by Rallye
https://www.sau.com.au/forums/topic/311303-2007-nissan-350z-track/
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
