2001 Evo 7,
76000kms
Low Km std motor installed by NA Autosport (Neil Lowe) Mid last year.
Surge Tank
Custom braided lines from surge tank to engine
3 Fuel pumps (one in Normal tank, 2 in surge tank)
Sard twin entry fuel rail
Sard 1000cc inj
Jun 280 deg cams
Tomei Cam gears
Full exhaust from turbo back with decat
Tial BOV
Custom Water tank in boot
Battery relocated to boot
Earthing Kit
HKS Pod filter with cool air intake
Custom upper intercooler pipe
NGK Super power leads
Aftermarket oil cooler
HKS Twin plate clutch
Two way diff both front and rear
RDA rotors front and rear, ebc red stuff pads on front and project mu pads rear
ISC coilovers
Sparco fixed back drivers with lowered rails
Apexi power fc djetro computer
Blitz i-color boost controller
Greddy turbo timer
Carbon fibre exhaust surround
Vortex generator
MR style headlights (blacked out)
HIDs
Stock 7 rims painted black
Perrin shorty antenna
Ralliart peddles
Ralliart carbon fibre door trims
Carbon fibre eyelids
JVC mp3 head unit
Jap speakers all round (decent quality though)
Reason for the new motor was due to a certain mech from down south ruining my 2.3L build.
Car made 215kw on a very conservative tune, 18psi std turbo. This car is extremely responsive and a very quick car. It has so much potential for those that want to spend the money on a evo green will have a very very very quick car. Has every single supporting mod you could want. Im selling due to moving on.
$30,000 ONO
https://www.sau.com.au/forums/topic/311316-jap-spec-evo-7/
