Best time to go is mid morning to mid afternoon.
In the morning, people seem to be warming up and not going that hard. After the track starts to warm up a bit, people start to put down their fast laps. I haven't really hung out till they finish in the afternoon, my tyres are normally gone by then :P.
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5128758
Wooohoooo bout time we got you out there.
I will be there with the open wheeler and Rebecca is running the GTST. Mark wont be running, but he'll be jealous now.
There is a BBQ running most of the day and cold drinks all day.
Who is going to do the video? I've got the camera.
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5128761
did you email your paperwork/entry form to Barbara?
Yeah, got a email from James this morning. :P
P.s. Grumblebee looks likes this now cept with better matching wheels and a couple of stickers
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5129284
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
