Best time to go is mid morning to mid afternoon.
In the morning, people seem to be warming up and not going that hard. After the track starts to warm up a bit, people start to put down their fast laps. I haven't really hung out till they finish in the afternoon, my tyres are normally gone by then :P.
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5128758
Wooohoooo bout time we got you out there.
I will be there with the open wheeler and Rebecca is running the GTST. Mark wont be running, but he'll be jealous now.
There is a BBQ running most of the day and cold drinks all day.
Who is going to do the video? I've got the camera.
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5128761
did you email your paperwork/entry form to Barbara?
Yeah, got a email from James this morning. :P
P.s. Grumblebee looks likes this now cept with better matching wheels and a couple of stickers
https://www.sau.com.au/forums/topic/311445-sdma-hill-climb/#findComment-5129284
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
